Export pressure at node 'i' for each time step
Hello everybody,
I have carried out a transient simulation and I'm interested in knowing the value of pressure at a node 'n' at every time step. If I do File-Export I obtain the desired values but only for the current time step. I have found that I should do a chart and export it, however, I don't get to do it. I pick "XY - Transient or Sequence" and data series with expression "t", I pick time at x axis and pressure at the y axis. But I obtain a time-time plot! I will appreciate your help :) |
I usually do similar things during calculation (using execute-command, see links in my answer here) since it allows not to save dat files and perform large calculations on limited disk space. :) |
