Temperature continuity between domains
Old   May 28, 2015, 16:54
Default Temperature continuity between domains
R. Raimondi
Jackino777 is on a distinguished road
SOLVED: using the Fluent "Graphic and animation", instead of CFD-Post
Hi guys,
I'm trying to simulate a natural convection in a garage, with solar radiation and heat flux between the different domains, but there is no continuity between them and I tried a lot of configurations and thermal setups. Also I serched online and in the forum a solution, but I found nothing.
This one is an exercise model for this case:
Outside 30°C
Initial conditions 15°C
Terrain with a UDF temperature (from 24°C to 18°C)
Do you know how to have this thermal continuity between the fluid?
Jackino777 is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
interDyMFoam "time step continuity errors" kilroy OpenFOAM Running, Solving & CFD 4 May 7, 2013 01:39
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
