3D Pipe Flow Problem: Velocity profile is not symmetric
Old   May 27, 2015, 11:51
Default 3D Pipe Flow Problem: Velocity profile is not symmetric
malicemethods is on a distinguished road
Hello, I am modeling a concentric pipe flow problem. The geometry is simply two concentric pipes. Looking at the left side view, the face of the outer pipe end has a mass flow in boundary condition specified and the area of the inner pipe is the outlet tube, and has an outflow specified. I have used inflation on all the walls, with 15 layers, for a Y+value of 5, specifying the first layer height. I am getting issues with finer meshes where the velocity contour plot shows the velocity profile is not axis symmertric about the centerline axis the way it should be. The solution does not converge even after 1000 iterations. I suspect that it is due to different cell sizes, but shouldn't the problem exist for coarser meshes? Instead the problem persists even with finer meshing. What could be the problem? Should I increase the number of inflation layers? Screen shots attached. Thank You.
malicemethods is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
[swak4Foam] problem with a parabolic velocity profile Claudio87 OpenFOAM Community Contributions 5 May 29, 2014 09:30
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
