Laminar Burning Velocity Calculations with Fluent |
January 24, 2014, 09:26 |
Naseh Hosseini
Rep Power: 13 |
I am trying to run a simple case of premixed laminar methane-air flame.
In order to investigate effects of acoustic waves on it, but not for now. I heard that you can easily get wrong laminar flame speed in Fluent if your grid is not fine enough and if you use default values of single step chemistry. So I was introduced to make a quasi 1D model (on element in height and thousands in length) ans apply the mixture as velocity inlet and check the flame speed. I can run this simulation and the flame forms in a distance. Now how can I actually calculate the laminar burning velocity? I was told I can use this formula: S_Laminar = (1/rho_unburnt)*Integral{(rho*dY/dt)dx Would you please tell me how I can extract these parameters in Fluent? Thank you. |
May 12, 2017, 05:53 |
Laminar burning velocity
Hi, I am also trying to find the laminar burning velocity for Heat Flux Burner for premixed methane air flame using drm19 mechanism. If you have found how to extract the data to find laminar burning velocity, can you please let me know?
Kind regards, Adithya |
May 12, 2017, 06:25 |
Naseh Hosseini
Rep Power: 13 |
Dear Adithya,
You need to run your simulations in the quasi 1D domain I have mentioned in the original post, and then run it in transient mode and export the temperature profile or reaction heat profile for every few time steps. Then in Excel (or similar) you can calculate the flame movement speed. Depending on your inlet velocity you can then calculate it simply by a relative velocity concept |
burning velocity, fluent, laminar, premixed |
UDF inlet velocity profile mismatch with Fluent | ChristineL | Fluent UDF and Scheme Programming | 15 | November 25, 2016 06:45 |
laminar velocity profile | arashmarahel180 | FLUENT | 16 | October 16, 2015 12:08 |
Fluent Axial Velocity Definition | zoeburton1987 | FLUENT | 0 | June 7, 2012 09:34 |
some questions about fluent export velocity from ASCII? | edongliang | Main CFD Forum | 0 | May 3, 2011 22:22 |
Need Help on Fluent Modelling Laminar on BluffBody | ary | Main CFD Forum | 1 | May 19, 2005 05:59 |
