Combustible as DPM problem
Old   June 8, 2015, 05:16
Default Combustible as DPM problem
Anonymous
marauder is on a distinguished road
I'm doing coal combustion using PDF method.
I have two inlets through which both air and coal travel in together.
The Coal particles are given as combustible DPM injections at my two inlets.
I'm giving the total coal flow and selecting the scale the flow rate to face areas option.
Once my solution is converged, I'm observing that the DPM flow through both inlets is not equal and also the total injections through the inlets is less than the total flow I've given.
Any ideas or suggestions please?
marauder is offline   Reply With Quote
Can I solve MRF problem with DPM (Discrete Phase Model) ? aminem OpenFOAM Running, Solving & CFD 2 July 1, 2020 18:04
DPM mass source problem maazulmosaid FLUENT 0 April 25, 2014 06:25
DPM Parcel Number Problem Shane FLUENT 7 October 25, 2012 08:24
DPM Output Problem (Again...) DLINSA Fluent UDF and Scheme Programming 1 March 16, 2012 00:45
Problem in DPM Harpreet FLUENT 0 July 31, 2011 09:56
