June 12, 2015, 04:45 |
GAMBIT meshing / VOF method
Raph
Rep Power: 10 |
Hello everyone !
I am modeling a flow over a spillway (reservoir + spillway+stilling basin) and I am using the sofware GAMBIT for the geometry and meshing. As it is an open channel flow I am planning on using the VOF method in FLUENT later. Therefore I have some question concerning the mesh that can be used for the VOF method. - Is there any limitation (like a minimun size) concerning the cells ? (I have quite a big volume and low computational power so I can not do a really precise mesh even with size function )? - I have divided the geometry in multiple volumes, I just wanted to know what happened at the jonction between two volumes ? Is gambit joined automatically meshes? - What is the point of meshing a surface/edge before meshing the volume ? Last I have a question concerning the computational time,can you predict an approximate computational time with the number of cell, the RAM of the pc and the model used? Sorry if all the questions do not belong to the same section and thanks for your patience. Best regards. |
June 12, 2015, 06:25 |
Maxime Perelli
Rep Power: 41 |
-no cell size limitation --> your hadware will limit you
- if splits are well done, gambit will connect the volumes, and at their common face, gambit will apply interior BC -if you mesh surface or edge before volume, gambit, will mesh the volume in fucntion of the mesh of the lower topology (I would use size function if mesh of lower topology is smaller than mesh volume) -it really depends on your hardware and also your physics
In memory of my friend Hervé: CFD engineer & freerider |
June 12, 2015, 07:39 |
#3 | |
Raph
Rep Power: 10 |
Thank you Max for the quick answer, I just made a mistake on the first question, it should be
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 13:12 |
[ANSYS Meshing] ANSYS Meshing vs GAMBIT | aerospain | ANSYS Meshing & Geometry | 0 | September 28, 2011 06:05 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 10:35 |
Gambit: too long meshing time! | delsolman | FLUENT | 1 | January 29, 2008 19:06 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
