Nusselt number 4.36 validation in a tube in constant heat flux situation |
May 2, 2012, 09:00 |
Felix
Rep Power: 14 |
Hi,guys.
According to classic heat transfer knowledge ,the Nusselt number in a fully developed tube with constant heat flux should be 4.36 . CFD code like fluent is so powerful ,so I want to validate the problem in fluent .And if I model right ,I should get the right Nusselt Number. But maybe there is something wrong in my model process , I just can not get the Nusselt number as described above . These is the process below. according to experience :the length of entry region l=0.05Re×Pr。 Material is water : and I set Re=100. Re=Rho×velocity×D/viscousity. then I get inlet veloctiy=0.1m/s. Pr(30Celsius-60Celsius)is about 3 .then we get the entry length l=0.05×100×3=0.15m. I build a cylinder in Gambit with the dimension below: D=0.1m,L=0.3m. Boundary condition: inlet velocity :v=0.1m/s .T=300K. outflow in outlet。 heat flux of wall =q=400W/m^2. the conductivity of water :lamda=0.6. I use the 3D single precise solver to solve the problem. Set the residual to 10-4. At the same time ,I set a temperature monitor point in the middle point at the tube . The calculation of Nusselt number: Nu=h*D/Lamda. h=q/DletaT=q/(Twall-Tref). Twall is the temperature of wall of the tube ,Tref is the average temperature of the section I choose in the fully developed region. I create a section in fully developed region . plot temperature coutour of this section ,and I get max temperature in the wall is 300.948K . The difficulty comes as I want to calculate the average temperature of the section I created. According to heat transfer textbook ,Tref=Tm=(Intergral of(u×T)in seciton )/(pi×(D/2)^2×Veloctiy)。 The result of the section is 0.002341306。So Tref=Tm=0.002341341/(3.1415926×0.05^2×0.1)=298.2555K. Then h=q/(Twall-Tref)=400/(300.948-298.2555 )k=148.560817084494 w/(m^2.k). At last ,I get Nu=h×D/Lamda=148.560817084494*0.01/0.6=2.4760136180749 != 4.36. I don't know what was wrong with the above process .Can somebody so kind to point the error in my process ? |
May 2, 2012, 09:37 |
#2 | |
Lucky
Rep Power: 65 |
Lastly, you can more easily simulate fully developed flows using the periodic boundary conditions. If you don't care about entry length effects, I recommend you do fully developed flows this way. Just wanted to inform you that the feature exists. |
May 2, 2012, 09:54 |
#3 | |
Felix
Rep Power: 14 |
Thank you very much . In fact I want to investigate the Nusselt number along the axial direction. I am not very sure about the calculate method of average temperature in the section of the tube . Fluent provide so many method to calculate the average temperature in a section ,like facet average ,vertex average and area-weighted temperature and so on . But I don't know which is right for my problem. I use different methods and I get different answers . I was really confused by this. |
May 2, 2012, 13:02 |
#4 | |
Lucky
Rep Power: 65 |
May 3, 2012, 07:21 |
Felix
Rep Power: 14 |
Thanks much to your suggestions . I use periodic boundary condition now and iterate again and at last I get a good result. I am not sure about the length of entry region .
I set the bulk temperature of inflow of tube as 300K,and transfer the velocity 0.1 m/s to mass flow rate as 0.0078437714588745 kg/s. Here is my result : bulk temperature is 300.0098 and wall temperature is 300.4001 .then I can get Nusselt number as 4.259307. Now I want to use double precision solver to solve it again to get Nusselt number ,maybe it is closer to 4.36. Thank you very much for your help again. You are really a nice guy. |
June 18, 2015, 13:25 |
shirin patil
Then how will find the heat flux for constant wall temperature to find the nusselt number
June 18, 2015, 22:09 |
Felix
Rep Power: 14 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
validating nusselt number in flows over parallel isoflux heat plate | mkamalhilmi | FLUENT | 0 | September 5, 2014 04:57 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
