Fluent
1 Attachment(s)
Dear all,
In LES run , I saw a peculiar problem and want share it with you all. I defined a point in the domain i.e. y_vel_10rad_ to get temporal quantities. Then I continued simulation and saw that an extra scaled residual under the head y_vel_10rad_ (as highlighted in the attached image) apart from x,y,z and continuity. Can any body help me, how to remove it, because of it solution is not converging. Thanks, Nasiruddin |
It looks like you have made a monitor and probably checked print to console. Simply uncheck it in gui or disable print in tui.
