I am trying to analyze air compressor in fluent need help in BC's
Old   January 11, 2016, 04:30
Default I am trying to analyze air compressor in fluent need help in BC's
kedar manohar
kedarjan is on a distinguished road
I have a geometry created in solidworks for air compressor with inlet casing fins and outlet and inside compressor blades.
I am trying to do cfd analysis using fluent.
What boundary conditions should i try?
I tries pressure inlet and pressure outlet but the model diverges
even tries mass flow inlet and pressure outlet then x-momentum diverges.
Which model I should use i used LES solver and Spalart-Almaras solver. but got divergence in both models
Can anybody help me out with this?
Thanks
kedarjan is offline   Reply With Quote
air compressor, fluent
Appropiate BC's for the inlet/outlet in an air chamber zfaraday OpenFOAM Pre-Processing 9 March 15, 2018 08:17
What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? nikesh FLUENT 0 January 29, 2015 23:32
Ansys Fluent UDF - for Data Center Air flow management kedarjan Fluent UDF and Scheme Programming 13 November 13, 2013 04:20
cfd modeling of a relieving gas into air by fluent montazer1012 Main CFD Forum 0 July 19, 2011 07:51
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
