Unfortunate interface zones - solid-fluid analysis
Old   July 17, 2015, 11:31
Default Unfortunate interface zones - solid-fluid analysis
Idiom_1 is on a distinguished road
Hello Dear Users,
i would like to ask you, what did i made wrong if in my simulation of fluid flow (as tube) through solid body only fluid get temperature from solid body.
What i mean, i have got aluminium body with hole inside, and there is fluid zone. I made simulation that fluid flows through that hole in aluminium. I made aluminium temperature about 900K and water 300K. In my results I see water at begin got 300K and in outlet about 600K, and that looks cool. But the problem is, temperature of aluminium doesn't change even a bit. Still 900K. Is not possible, for usre water get some heat from aluminium. Have u got any ideas what i made wrong?
http://wrzucacz.pl/file/6861437146792
Please take a look at that model (it's really basic, and I guess for most of you it's so simply, i just spend more time at that problem and I know only theoretical informations, any moves forward...)
Thank you for any suggestions,
Have a nice time
__________
Of course I realize that water temperature 600K is a bit too high, but it doesn't matter about values at that moment, just want to make a complete simulation with heat flow in both sides not only solid->fluid.
Idiom_1 is offline   Reply With Quote
Fluid solid interface heavenlysins Fluent Multiphase 0 May 20, 2015 18:52
Fluid solid interface heavenlysins Main CFD Forum 0 May 20, 2015 18:29
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Modeling Solid and Fluid at the same using Interface BC..Help needed Prince Jassal Main CFD Forum 1 June 12, 2013 05:07
