February 6, 2018, 05:31 |
"Temperature too low for cell" error message
Pasquale Natale
Rep Power: 14 |
Hi guys,
I'm experiencing an issue while using EDC method with version 18 of Fluent. I'm forced to use EDC method since the Damkohler number into my domain varies very much. Moreover, I'm using a multi-step kinetic scheme, so EDM is not applicable. When I use this setup, I get this warning message: Temperature too low for cell=XXX on thread=YYY at node=ZZZ And this message is repeated thousands of times. I noticed that this "reporting" slowed down my run (by monitoring cpu usage of fluent processes). So, I'm trying to overcome this issue by "muting" these warnings. When I asked tech support this, they answered me to disable limiter-warnings (solve/set/limiter-warnings off). But, since this warning is NOT relative to limiters, it didn't solve my issue. Please, consider that this warning message did never appear in previous versions of Fluent (until 18). Have, anyone of you, got this issue and found a workaround to overcome this issue? Thank you for your time. |
March 20, 2019, 04:37 |
Jarief Farabi
I am facing same problem with fluent 18.2
March 20, 2019, 09:29 |
Lucky
Rep Power: 65 |
This type of message can also appear when a cell temperature outside a property curve (specific heat for example).
eddy dissipation concept, fluent, reacting flow |
Display Modes | |
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 20:00 |
Wrong interface curvature capturing and contact line calculation at low capillary nu | Mahmoud_aboukhedr | OpenFOAM Running, Solving & CFD | 0 | April 14, 2015 15:04 |
Low Pressure, Low Temperature | Luke | CFX | 0 | August 4, 2006 19:36 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
CFD code for very low Re Flow | Raj | Main CFD Forum | 2 | May 31, 1999 23:06 |
