August 5, 2015, 11:24 |
High AoA modified C-Mesh for a 2D airfoil
Rep Power: 10 |
HiĦĦ
I'm working on a 2d airfoil and I am not getting good results at high AoA even before the stall. I have created this modified C-mesh in order to orientate the cells with the flow direction, and I was wondering if it this mesh is ok for this purpose. With this mesh I get y+~1 and I am using k-omega(2 eqn) SST model. |
August 5, 2015, 15:33 |
anonymous
Rep Power: 12 |
Which Reynolds number are you using? Could you describe your fvScheme and your fvSolution? Which is the AOA? If it is high maybe your problem is highly unstable and you need to use URANS to solve correctly the geometry
August 5, 2015, 15:55 |
#3 | |
Rep Power: 10 |
Model: k-omega(2 eqn) SST model Scheme: Simplec Gradient: Green Gaus Node Based Pressure: Second Order Momentum: Second order Upwind Turbulent Energy: Second order Upwind S dissipation rate: Second order Upwind Boundary Turbulent intensity 1 % Cl 10% overestimated Cd 40% overestimated |
[ICEM] unstructured 2d airfoil mesh | Mazur | ANSYS Meshing & Geometry | 21 | June 7, 2023 03:48 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 05:10 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
