Operating Pressure and Outlet Pressure
If I would like to work with 1 Pa pressure. So I Need to set Operating Pressure as 1 Pa and pressure outlet 0 Pa? It will Change if the pressure outlet of the Domain changes? For example, how would it be in the following 2 cases? 1) pressure outlet of the Domain = 1Pa 2) pressure outlet of the Domain = 101325 Pa thanks |
The default operating pressure is 101325 Pa. Pressures are specified in gage pressures so if you set the operating pressure as 1 Pa and:
1) pressure outlet = 1 Pa the outlet would be at an absolute pressure of 1 + 1 = 2 Pa 2) pressure outlet = 101325 Pa the outlet would be at an absolute pressure of 1 + 101325 = 101326 Pa |
Thank you for your answer.
So based on what you have said, if I set the Operating Pressure as 1Pa, and outlet pressure as 0Pa, then the absolute Presurre in the Outlet will be --> 1 + 0 = 1Pa, correct? So I set right because I would like to work with low pressure, correct? |
Yup. :)
Good luck. |
