August 16, 2015, 22:42 |
DDT in closed straight pipe
hazwani
Rep Power: 11 |
I have a question. I am investigating gas explosion behavior involving premixed methane-air mixture in a closed straight pipe. I mean no inlet or outlet. I used finite rate/eddy dissipation, k-epsilon model. It was adiabatic wall. I tried to ignite the mixture by patching with high temperature but still got very low pressure profile. Do you have any idea how to overcome this problem? Thanks for your help. I'd really appreciate. Have a good day. |
August 18, 2017, 09:25 |
#2 | |
Also, I believe your initial condition is so important, try to set it, same as the experiment you have. Also, you should check your mesh resolutions, most of the times combustion problems are so sensitive to your mesh resolutions, and you need to satisfy a certain amount of points per half reaction length. Good Luck, Reza |
Display Modes | |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 11:14 |
Help UDF to Boundary Conditions in Closed Loop Pipe | Blader | Fluent UDF and Scheme Programming | 2 | May 14, 2012 10:48 |
Closed loop pipe flow | maddalena | OpenFOAM Running, Solving & CFD | 34 | August 16, 2011 12:46 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
