jws |
August 25, 2015 18:05 |
Initializing a Pressure Vessel
Looking to evaluate the standard problem of a closed pressure vessel bleeding out through a series of pipes. I have assembled my pipe section with orifice and run the problem with an inlet having a constant velocity and then reran the model with a constant pressure inlet. I now want to attached the pipe section to a defined volume with a specified initial pressure and evaluate the flow through the pipes as the pressure vessel bleeds down. My problem is how to define an initial pressure level within the vessel alone. I am thinking that the solution has something to do with making an initialization run which somehow only brings the pressure vessel volume up to the pressure level I want, but I have yet to find a Fluent example which addresses this problem. Seems strange since a pressure vessel bleeding down is one of the basic problems one would find in any fluid dynamics course. Any suggestions on how to initialize the pressure vessel volume?
