Solution inizialization
Old   September 2, 2015, 02:57
Default Solution inizialization
Umberto
cinclus is on a distinguished road
Dear all,
I'm carrying on the analysis of a flapping wing in 2D, especially focused on hinge moment.
I usually start with a steady analysis till convergence and then switch to a transient analysis.
When I simulate 0 degrees of angle of attack I noticed that sometimes the retrieved hinge moment does not have a symmetrical pattern, which is supposed to have being the airfoil and the flap oscillation symmetrical. But, if I stop the calculation and start again, without closing the window, with first steady and then transient simulation, the hinge moment appears to be symmetrical.
Provided I do not change any parameter, do you have any idea where my issue is?
Thanks
cinclus is offline   Reply With Quote
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 15:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 12:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
solution singularity litonx OpenFOAM Running, Solving & CFD 1 February 21, 2007 01:32
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
