making periodicity in Stationar in Fluent under multiple reference frame (mrf)
I am trying to simulate a rotor in hovering. To make mesh size small, I wish to use periodic BCs. In MRF, two fluid zones are defined: 1: Moving Zone (make periodic zones are successful) 2: Stationary Zone ( making periodic zones are unsuccessful) How can I make zones periodic in the Stationary Fluid Zone? Any help, suggestion, comment, plz? |
Yes, you can make them periodic!!!
How I can make periodic? It gives error.:
Failed to make zones periodic. Error object: #f Can you explain? Mesh_Image |
Hi.
I tried on both models and used three methods. What I did was: (1st method) ---> sucessful 1. Made the zone rotation axis to Y axis 2. Change per2 and shad2 to interface 3. used interface panel and make the mesh periodic 2nd method (not successful): 1. Made the zone rotation axis to Y axis 2. Used these command. define > bc > mz > mp > select pair of periodic surfaces 3rd method: (not successful): 1. Rotate the model so that axis of rotation is Z axis. 2. Used these command. define > bc > mz > mp > select pair of periodic surfaces 3. Possible problem is that axis of rotation is not passing through center of periodic surfaces. You should do it in the meshing software. Note: Why are you using 180 deg sector? |
I have two blades, so 180deg sector.
I used Ansys Meshing, in moving zone, periodic zone was successful. I am sorry, not to tell you the rotation axis, i think (0.045, 0, 0). Now I tried in Pointwise, periodic zones are successful but getting the error Code:
Periodic zone 7: average rotation angle (deg) = 180.000 (180.000 to 180.000) |
there is something wrong with origin parameters for the stater.
Can you make it periodic in gridgen? |
In gridgen, I cannot apply "Periodic BC" for fluent. I did this in fluent.
Finally,
I am successful making zones periodic in Ansys Meshing by using Match Control and proper definition of Coordinates. Job is done. Thanks for the help guys. |
