August 31, 2015, 10:49 |
DPM temperature of particles
Linwei
Rep Power: 11 |
hi all,
Is it possible to get the temperature of particles if I run a case about coal particle combustion under DPM model. If possible, how can I get the data? Thanks a lot. |
December 9, 2015, 05:10 |
RCris
Rep Power: 10 |
What software are you using?
December 11, 2015, 09:58 |
Giorgio
Rep Power: 10 |
sure you can. before starting the run you have to add the temperature particle variable: in calculation activities, export particle data history, in add variables you will find the particle temperature, add it and at the end of the computation you will have it as a result. i have a question for you: what do you use as post processor, for visualizing the particle in the domain?
dpm particle temperature |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
DPM for steady flow with unsteady particles tracking | yahya | FLUENT | 0 | March 28, 2013 13:28 |
size particles in DPM | nasser | FLUENT | 2 | December 7, 2012 15:15 |
DPM particles in swirling flow | rsslnt | Main CFD Forum | 1 | January 24, 2012 07:32 |
