Home > Forums > FLUENT
how to make the negative pressure as zero in surface intergration
Old   September 1, 2015, 02:20
Default how to make the negative pressure as zero in surface intergration
shaktinaik is on a distinguished road
i work on hydrodynamic fluid bearings. here due to cavitation of fluid i observe negative pressure. when i calculate the surface integrals for the load carrying capacity, the negative pressure is also integrated.
can you please suggest me how can i make the negative pressure as zero in the calculation of the surface integrals?? it should also be zero when i calculate the mid plane pressure plot.
i have attached a mid plane pressure plot. you can see that the curves reach negative pressures too. i want that to be neglected, i.e, zero as it is my boundary condition.
please help.
shaktinaik is offline   Reply With Quote
Old   September 1, 2015, 02:27
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
here it is http://www.cfd-online.com/Forums/flu...t-working.html
Far is offline   Reply With Quote
Old   September 1, 2015, 09:57
it looks like some coding work. can i just not do it using the software abd some tools in it??
Old   September 1, 2015, 16:38
Lucky Tran
LuckyTran will become famous soon enoughLuckyTran will become famous soon enough
I'm not familiar with the cavitation model but isn't the absolute static pressure clipped at 0 anyway? You have a negative absolute pressure or gauge pressure? A negative gauge pressure should be acceptable is it not?
Old   September 2, 2015, 04:11
pakk will become famous soon enough
I agree with what LuckyTran said, in my experience the absolute pressure is never below zero...
But to literally answer your question, you can always output results to a text file and read that in matlab, octave, excel or your favourite analysis tool, and set the negative values to zero, and do the integral calculation yourself.
pakk is offline   Reply With Quote
Old   September 2, 2015, 10:17
yes i have put reference frame as absolute and the gauge pressure is zero.
i have attached an image wer u can see the negative pressure devloped. i need that part to be zero.
its the fluid part.
how can i do that????
how can i integrate values in excel???? please help.
Old   September 2, 2015, 10:55
Andrew Kokemoor
Kokemoor is on a distinguished road
This is pretty easy in CFD-Post. If you make an expression for positive only pressure:
max(0[Pa],Pressure)
you can use that to calculate force. For example, the adjusted pressure force in the x direction:
areaInt_x(PosPressure)@surface
where PosPressure is the expression you defined first and "surface" is the name of the boundary you want to sum forces on. You'll probably want to include shear force as well by integrating the appropriate Wall Shear variable.
Kokemoor is offline   Reply With Quote
Thread Tools
Trackbacks are On
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 5 September 19, 2017 00:09
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
Negative absolute pressure in core vortex clod FLUENT 1 March 11, 2015 06:33
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
