flow over no of cylinder
Old   September 21, 2015, 12:11
Default flow over no of cylinder
vignesh.r
mrvignesh91 is on a distinguished road
i have inlet temp fluid 80 ,cylinder temp 10,inlet pressur 15pa, no of cylinder 20... i want to find what is outlet temperature and pressure of fluid???
inlet temp press ,cylinder temp,values are given in solvent(boundary condition),what i have to give for pressure outlet and temprature(defaulty it is there as 0pa and 300k) actually i want to find those temp and pressur of outlet....i am in confusion what data have to give for outlet(boundary condition)
mrvignesh91 is offline   Reply With Quote
Old   September 23, 2015, 00:59
Lucky
You're still missing some information on the velocity/mass-flux/mass flow rate but I think you can use pressure outlet with targeted mass flow rate once you figure out the appropriate mass flow rate.
Old   October 6, 2015, 00:37
vignesh.r
thANK.....WHAT HAPPEN IF GIVE IT AS OUTFLOW
Old   October 6, 2015, 00:42
Default Regarding reciprocating action of piston
vignesh.r
PLEASE any one give udf for the reciprocating wall with frequency of 50hz
Drag force coefficient too low for a flow past cylinder at Re= 1e05 Scabbard STAR-CCM+ 2 June 5, 2020 15:44
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low Scabbard Main CFD Forum 21 June 19, 2018 14:58
Flow around cylinder free to rotate Jonas Holdeman Main CFD Forum 5 August 3, 2015 18:54
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
