Can not get Y plus >=30 small internal channel flow k-e non equilibrium wall function |
September 29, 2015, 15:46 |
Gowain
Rep Power: 11 |
I can not seem to get the Y plus value towards 30 without making the mesh ridiculously sparse. The geometry is of a channel 40 mm high with two heated blocks in tandem downstream - the case is in 2 D and k epsilon with non equilibrium wall function. The inlet velocity is 5m/s - relatively high, Y plus is 6 to 10, to get Y plus close to 30 the grid is ridiculously sparse. Is there a need for Y plus to be 30 or will my results be adequate with Y plus 10. - is the non equilibrium wall function having this effect or the size of the geometry. regards |
September 30, 2015, 09:18 |
Rep Power: 11 |
Display Modes | |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
volume flow through internal hole in the wall | wouter | OpenFOAM | 4 | February 14, 2011 07:36 |
Setting up k-e turbulent wall function for two-phase flow | metro | OpenFOAM Running, Solving & CFD | 1 | August 23, 2010 06:30 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
