Dynamic meshing of oscillating airfoil (2d)
Like Tree1Likes
  • 1 Post By poya0070
Old   August 2, 2013, 01:19
Post Dynamic meshing of oscillating airfoil (2d)
abhiramBA is on a distinguished road
I am trying to simulate the oscillatory motion of an airfoil. I have successfully compiled my udf and the library is also loaded. I do not know what settings I should use in the dynamic mesh. Only the airfoil seems to oscillate and the grid stays as it is.
Also, when I solve, I get an error saying "Update-Dynamic-Mesh failed. Negative cell volume detected."
Kindly guide me through the dynamic meshing.
abhiramBA is offline   Reply With Quote
Old   August 6, 2013, 22:50
hy2049 is on a distinguished road
Hi, I'm doing the same thing with you. I also met some problems. So would you like to share your files with me and let's figure out the problems together.
hy2049 is offline   Reply With Quote
Old   August 7, 2013, 01:41
Alright!
Here is my grid.
Old   August 7, 2013, 03:05
Paritosh Vasava
vasava will become famous soon enough
'Negative cell volume' error indicates that you haven't done the 'dynamic mesh' settings properly.
Can you post your settings here? It would help to help.
vasava is offline   Reply With Quote
Old   August 7, 2013, 03:11
Paritosh Vasava
More over...
1. The mesh/boundary displacement per time step can not be more that the smallest element size of your mesh.
2. The mesh/boundary displacement per time step should be selected so that the minimum quality of the mesh (after update) does not exceed the worst quality of the mesh you have declared.
Old   August 7, 2013, 03:31
Originally Posted by abhiramBA View Post
Alright!
Here is my grid.
Is that better to use an unstructure mesh if we want to use dynamic mesh here?
Old   August 7, 2013, 05:38
Paritosh Vasava
Yes indeed. Using triangular mesh elements would be more appropriate for dynamic mesh.
Old   September 7, 2013, 13:17
Exclamation negative
poya
poya0070 is on a distinguished road
about this problem i study in fluent lecture that must be to have a skewness less than 0.7 or acceptable(less than 0.9-0.95, i dont know more).
but in my project(same ur project) resolve this notice and problem yet appear(Although in more time step) and in preview mesh motion the quality orthogonal after several time step is less than 0.05. and then error ......
what setting in remeshing and smothing is required to resolve this problem ?
Durga Sravan likes this.
poya0070 is offline   Reply With Quote
Old   March 8, 2017, 13:49
saif
saif_uzair is on a distinguished road
Hi Abhiram ,I am doing the analysis of pitching aerofoil(symmetrical) , about center of the chord can you please help me with the process and udf.
my mail id bourne0619@gmail.com
Thank YOu
saif_uzair is offline   Reply With Quote
dynamic mesh, oscillating airfoil, pitching airfoil, udf
[mesh tool] meshing airfoil naca 0015 peter pan ANSYS Meshing & Geometry 0 June 15, 2011 09:26
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 11:01
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Oscillating airfoil problem ganesh Main CFD Forum 2 June 27, 2005 13:57
Meshing An airfoil with a simple plain flap S. Kalam FLUENT 7 January 30, 2005 20:22
