Getting a Negative Drag_Coefficient
Old   October 12, 2015, 23:38
Smile Getting a Negative Drag_Coefficient
fangwei
yshen303 is on a distinguished road
Hello Everyone
I am running a 2D simulation over a Airfoil via Fluent.
I am getting a good Lift Coefficient, but a negative Drag coefficient.
Is there anyone experiencing the same issues while running the CFD?
Besides, for the initialization method. Is there difference for Hybird and Standard initialization. which one is better?
yshen303 is offline   Reply With Quote
Old   October 12, 2015, 23:59
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
please check
1) is your mesh fine enogh.
2) is your solution converged.
3) values for force vectors, are they defined correctly for specified AoA.
chapter 3:
-crossing the threshold-
Bharatt is offline   Reply With Quote
Old   October 13, 2015, 00:54
fangwei
Originally Posted by Bharatt View Post
please check
I think the Mesh is fine, I got a decent Lift_coefficient already
for the (3), what is values for force vector?, for the angle of attack, in the farfield setting, the direction of incoming air is defined based on x, y unit vector component.
for zero AOA, x:1 y:0 right?
Old   October 13, 2015, 01:15
Bharatt's Avatar
Bharat
yes,
for(drag monitor) specific AoA
X=cos(AoA)
Y=sin(AoA)
chapter 3:
Old   October 13, 2015, 08:00
Devesh Baghel
devesh.baghel is on a distinguished road
Is direction vector correctly defined while calculation of drag ?
sometimes happened, while defining opposite direction of vector which reflects negative value.
devesh.baghel is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
