laminar velocity profile
Old   July 14, 2010, 13:08
Default laminar velocity profile
arashmarahel180 is on a distinguished road
Hi
I need urgent help
I simulate a pipe with 100 micron diagonal, there is water inside pipe. the inlet velocity is 0.4 m/s, it's on laminar regime. when I plot velocity profile on output, it shows maximum velocity is 0.6 m/s. it's wrong because in laminar regime maximum velocity is 2*(Average velocity). plz help me to solve this problem
best regard
arashmarahel180 is offline   Reply With Quote
Old   July 14, 2010, 16:59
karine
thecfduser is on a distinguished road
Hi
refine ure mesh.
Maybe a double precision solver will help.
Regards
thecfduser is offline   Reply With Quote
Old   July 15, 2010, 04:17
Hi dear friend
I use double precision solver and it still has error
Plz help me to solve this
best regards
Old   July 15, 2010, 14:59
karine
Hi
Refine ure mesh. Use a finer mesh and compare with the first one.
u do the same thing untill u get the same solution.
If u want to have the real solution of Navier STokes, use a boundary layer mesh also.
Remember that a solution that is not independant of the mesh size, is never so usefel in CFD.
Regards
Old   July 15, 2010, 15:15
Hi
thanks for ur answer
I want to simulate 2D rectangular channel, when I draw velocity profile on outlet it shows wrong maximum velocity
can u help me?
regards
Old   July 15, 2010, 15:17
karine
How can u simulate a rectangular channel in 2D?????????????????????????????
Old   July 15, 2010, 15:30
excuse me I'm new in fluent
my thesis is about simulation microchannel with rectangular cross section
Do u think it is not possible to simulate it in 2D?
Old   July 15, 2010, 15:42
Steven Qhin
chaozhong.qin is on a distinguished road
Regarding your case, i have two comments:
First, why do you want to simulte this problem? In fact analytical solution exists, if your case is single-phase, laminar flow.
send, when you can simplify a 3D to 2D, it means in third direction you can extend your geometry without limitation(no viscous effect), hence, for your case, you can not use 2D model.
Anyway, I hope it is useful to you.
chaozhong.qin is offline   Reply With Quote
Old   July 15, 2010, 15:46
karine
yes as chaozhong says, u cant extend ure geometry.
Unless the width of ure channel can be considered as infinity...
Anyway, flow in rectangular channel is highly complex because u have secondary and corner vortices motion. It stills an actual theme of research.
U have analytical solution for the laminar case only.
Ask me if u still need something
Old   July 15, 2010, 15:59
Steven Qhin
Thanks for your indication about this field.
I thought it was just a straigh channel with regular cross-section.
Good Luck!
Old   July 16, 2010, 13:24
Hi
thanks for ur answering, actually my M.s thesis is about microcahnnel. I have to simulate a microchannel with rectangular cross section. it has 4 velocity inlet and flow must be fully developed. when I simulate it with 0.4 m/s it showed maximum velocity is 0.6m/s and it must be 0.8
can u help me?
regards
Old   July 16, 2010, 13:38
karine
Hi
yes i can help u. No problem.
U must get 0.8 m/s for a fully developped laminar flow in a CIRCULAR channel. Not in a rectangular one.
I think u have a very bad professor that is helping u in this thesis.....
Get ure solution in a rectangular channel. Do anothere grid finer than the first and look if the solution is the same.
Old   July 16, 2010, 14:32
Steven Qhin
In fact velocity profile is not so sensitive to your mesh, not like the pressure drop.
Of course, you could use the hagen-poiseuille law to obtain the velocity profile.
Old   July 17, 2010, 04:33
thank u so much
I attach picture of my microchannel, I obtain the analytical solution for velocity profile in rectangular channel, velocity profile in inlets agreed with analytical solution but when two inlet join together, the velocity profile doesn't agree with theory, I don't know how should I do?
Old   July 17, 2010, 08:44
karine
Hi
i didnt understood ure geometry...where are the inlets??
what is ure Re???
Anyway look what u must do:
monitor variables in a point inside the domain and see how it behave. See if this variable become constant or if it do a cyclic behavior.
Old   October 15, 2015, 09:26
mechiebud
mechiebud is on a distinguished road
Hi I am new in CFD and writing code for laminar channel flow in 2D. But I am not able to decide the boundary and intitial conditions like u,v and pressure. I have used Poissuile formula for u velocity. But hot to initialize v and pressure. Thanks
mechiebud is offline   Reply With Quote
Old   October 16, 2015, 12:08
Daniel B
bgp723 is on a distinguished road
If you don't define any local friction factor UDF for a 2D rectangular channel, you are effectively simulating a flow between two infinite parallel plates.
In that case, 0.6m/s is correct (Umax = 3/2*Umean for flow between two infinite parallel plates).
I have also noticed that for finer meshes, it takes many iterations (in the order of few thousands) to reach the theoretical value. For example, for one of the cases I was studying, with about 5000 iterations for ~400x1000 (Ny x Nx) , my Vmax/Vmean was around 1.3. But when I ran it for about 20000+ iterations, it converged to 1.5.
bgp723 is offline   Reply With Quote
please help UDF for velocity profile in y-directio raju Fluent UDF and Scheme Programming 6 April 12, 2019 23:21
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 08:38
Velocity Profile Jeff FLUENT 1 November 24, 2008 08:21
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
problem with velocity inlet profile file Duncan FLUENT 3 November 21, 2005 07:28
