October 10, 2015, 11:09 |
Turbulence intensity
amine heroual
Rep Power: 10 |
hi i am doing the simulation for a axisymmetricjet impingement heat transfer on flat plate, different nozzele to plate and reynolds number testing but
how calculate the I (turbulent intensty %) for this case ( impinging jet) formule or correlation for calcul the I% please thanks . |
October 12, 2015, 04:45 |
Rep Power: 10 |
The ANSYS user manual has the equations listed for turbulence properties.
You can get the user manual by pressing F1 when Fluent is open, then just search 'turbulence intensity' The Theory manual gives a bit more in-depth description if you want it. |
October 13, 2015, 10:26 |
Ludo
Rep Power: 10 |
October 13, 2015, 12:10 |
Rep Power: 12 |
Dear amine hero
The turbulence intensity can be roughly estimated by considering the flow situation as the following: 1. Grid turbulence - intensity = approximate 1% 2. Wall bound flow - intensity = approximate 10% 3. Free shear flow (jet, wake, and mixing layer) - intensity = >10% Good luck Eakarach B. |
October 13, 2015, 14:28 |
amine heroual
Rep Power: 10 |
thank you I=0.16Re**(-1/8)
October 15, 2015, 00:12 |
Rep Power: 12 |
I=0.16Re^(-1/8) is developed by considering the fully developed flow in pipe. However, that formula can also employ to estimate the turbulence intensity in many flow situations.
Good luck. |
Turbulence Intensity at inlet boudary | egge24 | FLUENT | 1 | October 10, 2015 15:56 |
Turbulence intensity - cross wind on a body | Fabio88 | Main CFD Forum | 0 | May 4, 2015 03:44 |
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? | david39 | OpenFOAM Running, Solving & CFD | 6 | February 2, 2011 03:01 |
High turbulence intensity | wenfengxie | FLUENT | 1 | April 16, 2010 12:00 |
High Turbulence Intensity Problem | bwg | FLUENT | 1 | January 13, 2010 13:09 |
