November 2, 2015, 08:55 |
#61 |
Gustavo
Rep Power: 10 |
One additional question, I created the surfaces (holes of the pipe) in the Design Modeler as you suggested. Then Fluent recognized them as "interior". But in the CFD-Post I cannot find them to calculate the mass flow rate in each hole. Did I do something wrong?
November 2, 2015, 09:34 |
#62 |
Philipp
Rep Power: 26 |
Hmm... Can you select them in Fluent? You can use the "Reports->" functions to calculate mass flow.
The skeleton ran out of shampoo in the shower. |
November 3, 2015, 02:33 |
#63 |
Philipp
Rep Power: 26 |
Another idea: Is this compressible right now? Does it converge if you set it to incompressible?
November 3, 2015, 04:36 |
#64 |
Gustavo
Rep Power: 10 |
The mass flow worked thank you
Now itīs compressible (ideal gas)... I can try with incompressible to check weather converge or not... Thank you for the suggestion |
November 4, 2015, 06:32 |
#65 |
Gustavo
Rep Power: 10 |
Hi...
As incompressible (constant density) I could not see difference. But I used the density from nitrogen calculated at 1Pa and 298K (~1.13e-5 kg/m3). Or maybe should I use the density of nitrogen at standard conditions (1.14 kg/m3)? |
November 4, 2015, 07:13 |
#66 |
Philipp
Rep Power: 26 |
What does that mean? Didn't it converge?
November 4, 2015, 07:21 |
#67 |
Gustavo
Rep Power: 10 |
Means that all parameters residuals were less then 1e-5 and continuity residual ~1e-2 as were for compressible one...
What do you think about the density calculation? |
November 4, 2015, 07:25 |
#68 |
Philipp
Rep Power: 26 |
Density doesn't matter right now, just get convergence...
Did you try a second solver, such as "coupled"? I guess you use SIMPLE right now, correct?
November 4, 2015, 07:31 |
#69 |
Gustavo
Rep Power: 10 |
I tried SIMPLE and COUPLED...
I guess that my case is one of them that the continuity residual doesnīt achieve very low numbers because of a good initial guess... If I see the plot of some paramaters (Area weighted average) Velocity inlet, pressure inlet, velocity outlet... all of the converged to a constant and acceptable value... |
November 4, 2015, 08:47 |
#70 |
Gustavo
Rep Power: 10 |
If you would run as incompressible... which density would you use? Calculated using 1Pa and 298K or using 101325Pa and 298K?
November 4, 2015, 08:48 |
#71 |
Philipp
Rep Power: 26 |
Some lower one, such as 1 Pa.
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
mass flow | Wenbin Song | FLUENT | 0 | September 27, 2005 13:00 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
