Error: Divergence detected in AMG solver?
Like Tree1Likes
  • 1 Post By everdimension
Old   January 16, 2005, 17:58
Default Error: Divergence detected in AMG solver?
frank
What does mean and how do i fix it? I am runing a rosseland radiation model and it wont run past 1 iteration.
Frank
Old   January 17, 2005, 12:41
Default Re: Error: Divergence detected in AMG solver?
HASSAN ZOHEIR
you are using the segregated solver, so you must reduce the under relaxation factor as you can.
Old   January 18, 2005, 10:48
Tang
You could have a grid issue concerning high skewness. This can be checked by going to contours grid cell equiangle skew and select compute and check the min and max. You should be below .9. If over t5hen this could be your problem. It has happened to me a couple of times.
Old   January 19, 2005, 19:16
frank
thanks a million i will try this...
frank
Old   March 3, 2012, 23:09
Musango Lungu
Musa is on a distinguished road
In my case both the min and max skewness value is 1.305729e-10. is it good enough?
Musa is offline   Reply With Quote
Old   June 7, 2012, 17:09
ARUN V
a_run_91 is on a distinguished road
Hi all
I am analysing a simple external flow. ANSYS 13.0,pressure based, pressure-velocity coupling:coupled, k-epsilon(realisable,non equilibrium wall function)
Im having the same problem..error message:
"Initialize using the hybrid initialization method.
Checking case topology...
-this case has inlets & outlets both
-pressure information is not available at the boundaries,
so it will be initialized with constant pressure
iter scalar-0
1 1.000000e+00
2 3.467081e+06# Divergence detected in AMG solver: ads-0 -> Increasing relaxation sweeps!
Error: Divergence detected in AMG solver: ads-0
Error Object: #f "
My maximum skewness is 0.84 but orthogonal quantity is too low (10^-12).How can i improve orthogonality??where can we enter TUI commands ??
I tried reducin coupler number, under relaxation factors..etc...but no change in error (except , "Increasing relaxation sweeps!" is not printed in console any more). Even the second itration value remains the same for varied air velocities.
Any of you have any sort of solution to my problems ???? I am desperate to hear thoose.....
a_run_91 is offline   Reply With Quote
Old   June 7, 2012, 17:34
everdimension is on a distinguished road
Your orthogonal quality is way too low, this may very much be your problem.
To improve it you should work on your mesh.
First, you should analyse where the bad cells are. To do this, choose 'orthogonal quality' in the 'mesh metric' in mesh statistics in Ansys Meshing. A histogram will appear. You should press 'controls' and in the 'maximum' field enter '0.1', and then 'update y-axis'. That way you leave only the cells of quality less than '0.1' showing in the histogram. Now you can click the bars on the histogram and the bad cells will show on your model.
Minimum recommended orthogonal quality is 0.1, may be even 0.2.
There can be different reasons for having bad orthogonal quality. May be these cells appear on the border of tetra and hexa cells, may be you have a very small inflation thickness but very wide cells. May be something else. Good luck in finding out and getting rid of those cells!
potofus likes this.
everdimension is offline   Reply With Quote
Old   July 21, 2012, 13:29
ARUN V
THANKS a lot for your reply everdimension.....
Old   October 21, 2015, 04:38
Question Same divergence Problem
Omkar Patil
omkarpatil is on a distinguished road
Hello
with reference to the Divergence mentioned in the thread
me too facing the same divergence problem
I working on a Species transport phase change problem.
The cells I have used are hexahedral with 0 skewness.
Still I am facing the same divergence problem
Please give suggestions
Thank you in Advance
omkarpatil is offline   Reply With Quote
Divergence detected in AMG solver: ads-0 Patrino FLUENT 6 May 12, 2022 03:11
Divergence detected in AMG solver : k littlebroca FLUENT 1 May 13, 2011 01:31
AMG solver _divergence detected Shamoon FLUENT 6 March 11, 2009 07:59
divergence detected in AMG solver !!! yansheng FLUENT 0 September 27, 2007 11:22
divergence detected in AMG solver: Shekhar Jain FLUENT 1 September 18, 2003 09:31
