November 2, 2015, 08:31 |
IDEAL GAS: not fulfilled even though set up?
Gergö Schmidt
Rep Power: 10 |
Hi everybody!
My aim is to simulate pressure equalization in inviscid air (density: ideal gas; Cp = 1004.9 J*K^-1*kg^-1; M = 28.966 g*mol^-1). Therefor I patch 2 different regions with 2 different initial pressures. I have obtained converging results only with a density-based solver and I had chosen an explicit transient formulation with CFL=0.75 for starting. My continuity, velocity and energy residuals are nicely declining during calculation, BUT when I calculate my ideal gas resiudal with Absolute Pressure-R/28.966[g mol^-1]*Total Temperature*Density I obtain residuals up to 30% of the local absolute pressure. This is a problem, because I'd like to comprare the results with ideal analytic solutions. My questions are therefore: 1) Is my way of calculating the ideal gas residual (see expression above) correct? 2) If 1) is yes, what can I do to get results which are more consistent with the ideal gas law? Thank you and kind regards! Gergö |
November 2, 2015, 09:26 |
Rahul
Rep Power: 10 |
Firstly,why are you choosing transient simulation for solving the problem?
There is no need for including time-based simulation here.Just try with steady stste simulations.That might help you out! |
November 2, 2015, 10:02 |
Gergö Schmidt
Rep Power: 10 |
Thank you for replying, Rahul!
The pressure equalization I want to simulate shall take place in a shock tube and I am interested mainly in the properties (velocity, pressure difference, shape of face etc.) of the generated shock wave. Rarefraction waves and their reflections are of interest, too. I'd not be able to examine the waves, if I wouldn't use transient formulation. |
November 3, 2015, 07:03 |
Gergö Schmidt
Rep Power: 10 |
Problem solved. Question 1) has to be answered with 'No', because the variable Temperature (static temperature) is needed instead of Total Temperature (stagnation temperature), ergo the correct expression is
Absolute Pressure-R/28.966[g mol^-1]*Temperature*Density which is almost zero everywhere in my simulation. Which is super |
November 3, 2015, 07:32 |
Rahul
Rep Power: 10 |
Thank you mate! Am also new to CFD.I am trying to gain as much knowledge as i could in the area of CFD.Also thanks for sharing your experience with me
explicit dynamics, ideal gas, pressure equalization, residuals |
Ideal gas law and incompressible flow | Nick R | Main CFD Forum | 13 | May 27, 2019 14:38 |
Ideal Gas Mixture, non reacting | Ancioi | OpenFOAM Running, Solving & CFD | 5 | April 12, 2013 07:10 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Problem using ideal gas | mark | FLUENT | 3 | November 29, 2004 16:40 |
