Is the convergence of solution ok?
Like Tree2Likes
  • 1 Post By Achin
  • 1 Post By Achin
Old   November 1, 2015, 15:57
Default Is the convergence of solution ok?
Aja
aja1345 is on a distinguished road
I am simulating an by using Fluent. The convergence of solution is monitored by checking the residuals of the numerically solved governing equations. Moreover, in order to judge the convergence, the behaviour of other quantities, such as the total pressure at the inlet and outlet boundaries, and torque coefficient generated by the rotor, are also monitored. Here, the default convergence criterion of each residual is reduced in order to allow the monitored quantities to stagnate at consistent values.
Now, according the following figures, Is the convergence of solution ok? and particularly about residuals?
aja1345 is offline   Reply With Quote
Old   November 2, 2015, 05:08
Achin is on a distinguished road
I am unable to see your images. But I can suggest that don't just go by the scaled residuals. Other than that, it is also important to check the flux imbalance. Go to Reports and Fluxes. For convergence, the imbalance in fluxes should be less than 0.2% of the net flux through the domain.
aja1345 likes this.
Achin is offline   Reply With Quote
Old   November 2, 2015, 05:34
Aja
Thanks for yours answer,
First, My English language is not good.
I will correct these figure.
some questions:
Therefore,according to your statement, one of convergence considerations is, checking mass imbalance. in other words, i should check this until i understand that solution converge or not. Am I right?
According to the following link, i understood that mass imbalance is equal to absolute value of (inlet mass-outlet mass). but How mass imbalance is computed as a percentage?
http://www.cfd-online.com/Forums/flu...tml#post571301
Old   November 2, 2015, 05:39
Aja
Other figures:
Old   November 2, 2015, 06:40
Aja
According to the following figure, Is this such scaled residuals logical?
Old   November 3, 2015, 01:06
Fluxes reported are with signed conventions. So you don't have to do any subtraction. Just note the "Net Results" which is your imbalance. It takes care of how much flux comes in (+ve flux) and how much is going out( -ve flux).
Then to calculate percentage: ( (Net Result)/(Inlet Flux) ) *100 should give you the percentage imbalance and it should be less 0.2.
aja1345 likes this.
Old   November 4, 2015, 02:50
Aja
Thanks.
Why do you say that it should be less 0.2?
Do you can present a paper and link about this value?
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
In the case of convergence aja1345 FLUENT 1 July 31, 2015 03:58
Continuity Convergence Problem in CFX cfd seeker CFX 2 July 2, 2015 11:12
Solution Convergence Vignesh V OpenFOAM Running, Solving & CFD 1 July 15, 2012 11:31
solution convergence problem anbuselvan FLUENT 1 January 18, 2009 04:00
