January 23, 2013, 18:33 |
cfd fluent simulation of heatpipe
rajesh reddy
hi i am unable to simulate the heat pipe in fluent which has two phase flow is it required to give pressure outlet also for multi phase i am unable to use the porous zone too
January 24, 2013, 03:47 |
Philipp
Rep Power: 26 |
So what exactly is your question?
The skeleton ran out of shampoo in the shower. |
January 24, 2013, 06:56 |
SSL
Rep Power: 14 |
There is no need of using multiphase in heatpipe modeling
July 23, 2013, 17:48 |
Mohammad Bahreini
Rep Power: 13 |
hi all
i want simulate heat pipe with fluent,any body know how simulate this case in fluent?i know i must use VOF model for this,but i cant simulate boiling in pipe... pls help regard |
October 17, 2013, 02:56 |
multiphase flow -superheated steam
Muthu
Rep Power: 14 |
Hii Everyone...
I am using multi-phase mixture model.. my fluid are superheated steam(as a primary phase) and water-liquid (as a secondary phase). The problem was property of steam(enthalpy) wat i need supposed to get is not getting (for e.g) In my boundry condition enthalpy value of a steam from a steam table is h=3000kj/kg but wat i am getting from cfd results is nearly h=1200kj/kg... how to fix the problem ... |
April 28, 2015, 05:43 |
Heat Pipe Simulation in Fluent
Hello guys,
i am trying to design a heat pipe in ansys fluent. temperatures at evaporator and condensor are 50degree and 25 degree respectively. liquid fillinf ratio is 70%. so here are the conditions i gave in my simulation. i chose double precision, transient pressure based solver. model- multiphase-volume of fluid with energy equation on. In phase interaction - mass - number of transfer mechanisms - 1 Evaporation-condensation with both 0.1 frequency and saturation temperature of 320K. Surface tension of 0.072 n\m with wall Adhesion. Boundary Conditions - Evaporator as Pressure inlet Guage pressure: 0 Initial Guage Pressure: 0 Temp: 350K Condensor as Pressure outlet Guage pressure: 0 Back flow temperature: 0 Adiabatic as Wall No slip wall contact Angle: 70 I am not getting any proper result with these conditions. Rest all are kept default values. Please Anyone of you guys are familiar with the design, it would be great if you could help me |
November 7, 2015, 14:07 |
help
majid
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
Fluent CFD vs Fluent CFX | gpan | FLUENT | 0 | December 21, 2011 13:09 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
