Is there anyway toTurn a 3d axisymmetric flow into 2d |
November 9, 2015, 05:02 |
vahid
For example consider a sphere in a flow (turbulent),
one solution is to model a 3d model, but to reduce time of calculations of fluent you define periodic boundary conditions to reduce number of mesh elements but it's still 3d and compared with 2d models it takes lots of time, My question is can you solve flow over a sphere using a 2d model using symmetry boundary condition in gambit or another methods? Thanks |
November 11, 2015, 12:18 |
Lucky
Rep Power: 65 |
Fluent supports 2D axisymmetric simulations, which sounds like what you want to do.
You would generate a 2D mesh of the upper half plane and then specify the "line" that runs through y=0 plane as the axis boundary condition. It's a separate solver (in script you have to launch using 2d/2ddp instead of 3d/3ddp). In GUI you have to check 2D on the launch window. You might have some trouble generating a 2D mesh that Fluent will accept, but gambit can do it. |
axisyymetric |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? | shubiaohewan | Main CFD Forum | 10 | May 2, 2013 14:08 |
Axisymmetric Flow around a hollow cylinder with an extended flair | JLight | OpenFOAM | 5 | January 28, 2013 12:11 |
Convergence for axisymmetric flow | bl201 | Main CFD Forum | 5 | August 16, 2005 17:01 |
