October 8, 2017, 16:09 |
how coupled two solid faces thermally?
Mahdi
Rep Power: 8 |
Hi guys. I have a problem with fluent and I need some help.
As can be seen in attached photo, I have two box which are attached to each other. Cold water and hot water flows through upper and lower box respectively. The body of box is from aluminum. left and right side of both boxes are symmetry. Because in real geometry I have several of these boxes on top and down (hot,cold,hot,cold,...) I need to use periodic boundary condition for top and bottom surfaces. As I found I should define them interface in gambit and then in fluent from "mesh interface", select "coupled". So top and bottom surfaces should be attached to each other and have same temperature profile. But it didn't work and I don't know why?!!! Could you please help me? I just need to connect the top and bottom faces thermally (we don't have any fluid flow there). Thank you guys. |
October 9, 2017, 21:30 |
Alexander
Rep Power: 34 |
Hello
Try to use periodic boundary condition on the wall surfaces Best regards |
October 10, 2017, 11:43 |
#3 | |
Lucky
Rep Power: 65 |
Define your periodic boundaries as walls (or anything) in gambit. Make them periodic in Fluent. you can do /define/boundary-condition/make-periodic blah blah blah |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
