face loop
Old   November 24, 2015, 11:57
Default face loop
alian
alian is on a distinguished road
hello every body.. I have a few questions and I wish some one could help me here
First:: begin, end_f_loop and begin, end_c_loop :: could be used in 2D or only in 3D simulation?? and what's the difference between them??
second:: while using (begin, end_f_loop and begin, end_c_loop) and using F_P(f t) or C_P(c t) the return should be pressure but is it the total pressure or what??
could I use (begin, end_f_loop and begin, end_c_loop) in serial or only in parallel processor ??
thanks in advance.
alian is offline   Reply With Quote
Old   November 24, 2015, 13:47
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You can use in 2d or 3d, serial or parallel. f stands for face, c stands for cell. The difference is the definition of cell and face in 2d and 3d. In 3d the cell is the 3d element, the face is a 2d element. In 2d the cell is bidimensional, the face is the side of the cell.
C_P (c, t) is the static pressure in cell c.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   November 24, 2015, 23:11
alian
dear Daniele.. thanks for replay... is there any way to evaluate total pressure by UDF??
Old   November 26, 2015, 05:18
ghost82's Avatar
Rick
Yes,
read this and understand what is total pressure:
http://www.cfd-online.com/Forums/flu...-pressure.html
Once you know the definition, you can write your custom code.
Old   November 27, 2015, 00:27
alian
thanks for reply my friend
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
