[Sponsors] | |||||
joseph
Rep Power: 12 ![]() |
Hi everybody,
I am trying to model Liquid flow in a microchannel over air filled cavities using transient VOF in 2D. At low Reynolds numbers(Re<10) I m facing difficulties for convergence and often reversed flow appears. I m using a velocity inlet and pressure outlet condition. even after large number of iterations i am not getting expected pressure variation along the channel length. But at higher Re values i am getting fair results. what can be the reason for this instability at low Re values?. How can i rectify it? |
hi mate,
if you're using Patch tool, try using "Patch reconstructed interface" method which introduced in FluentV16. Also structured mesh always gives better convergence. And try switching between "Body face weighted" and "PRESTO!" for pressure interpolation. i don't really remember, but one of them gave fast convergence for my case.
ICEM, CFX and Fluent expert |
joseph
thank you sadjad for your suggestions......i m trying it.
joseph
hi sadjad,
i tried the structured mesh case and it gives better convergence but the streamlines obtained from this is slightly different from that of the unstructured case and is wrong. the problem is at sharp edges. but the streamlines from unstruct-mesh looks good eventhough converegence is slow. why two meshes with same BCs give different results? |
joseph
still my low Re problem persists......can i use Body force weighted scheme when
body forces are negligible in my case? |
#6 | |
Also in drag/lift cases and wall bounded problems (where boundary layer is of great importance), struct. gave me relative better results. what were your elements' aspect ratio. also try refining mesh in interfaces. for sharp interface, try using ANSYS16 introduced sharp interface capturing. it adds artificial compression for volume fraction equation. it has 3 methods (sharp, dispersed, sharp/dispersed). in theory, if you refine two meshes at a very low level, results should be same.
did you consider gravity?
joseph
thank you sadjad,
i didnt activate gravity, since i m studying microchannel flow with very small length scales the effect of gravity is negligible......so only forces are viscous force, pressure force and surface tension. |
#9 |
So the base choice would be PRESTO!.
#10 |
joseph
thank you,
i shall update developments.... |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| serial/parallel problem in force saving convergence history | behest | FLUENT | 11 | July 22, 2014 04:49 |
| Low pressure de Laval simulation convergence problem | heksel8i | FLUENT | 3 | July 22, 2013 11:28 |
| Convergence problem with thermal phase change model under low velocity conditions | pitisrisuk | CFX | 0 | July 21, 2009 12:21 |
| Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 11:47 |
| Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
