batch mode fluent - beginner
Hi guys,
im new here and i have some troubles using fluent 16.2 in batch mode. When im trying to use fluent in batch mode, it calculates, but does not get any solution. I don't even know how to describe it. I just post here my log and my batch script. I hope you guys can help me. I think i didn't initialize correctly, but im not sure and i have no clue how to do it better. Im trying it since some weeks and i still dont get into anything. I tried out some different initiliazions but in the end i only got a longer log with all parameters equal zero. So it wasn't really a step forward, at least now it recognizes it isnt doing anything useful and aborts the calculation. Some more informations: im running it on linux on the cluster of my university, at the moment i just run it with the GUI but i cannot start and leave it, because i have only 30 minutes core time before i have to restart fluent to get another 30 minutes. So i really need to batch or i have to sit home on this and just watch it calculate. I used a .dat - file which is already calculating correctly, which made me hope i dont need to initialize. This seemed to be a wrong assumption. thats my script: #!/bin/bash --login #PBS -N test1410-4 #PBS -M myemailadress #PBS -m abe #PBS -j oe #PBS -l walltime=:00:20:00 #PBS -l mem=2gb #PBS -l nodes=1 # Change to work dir: cd $PBS_O_WORKDIR # Provide ANSYS through modules call: module load fluent fluent 2d -g << EOFluentInput >komega.log file/read-case /bigwork/nhmgefte/fluent/PALOG/komega/komega_rad.cas file/read-data /bigwork/nhmgefte/fluent/PALOG/komega/-13-02000.dat /solve/init/init it 20000 file/write-data /bigwork/nhmgefte/fluent/PALOG/komega/freitag.dat exit yes EOFluentInput and thats my log: /sw/aws/eng/ansys_inc/v162/fluent/fluent16.2.0/bin/fluent -r16.2.0 2d -g /sw/aws/eng/ansys_inc/v162/fluent/fluent16.2.0/cortex/lnamd64/cortex.16.2.0 -f fluent -g (fluent "2d -r16.2.0 -path/sw/aws/eng/ansys_inc/v162/fluent -ssh") /sw/aws/eng/ansys_inc/v162/fluent/fluent16.2.0/bin/fluent -r16.2.0 2d -path/sw/aws/eng/ansys_inc/v162/fluent -ssh -cx tane-n008.css.lan:52565:57824 Starting /sw/aws/eng/ansys_inc/v162/fluent/fluent16.2.0/lnamd64/2d/fluent.16.2.0 -cx tane-n008.css.lan:52565:57824 Welcome to ANSYS Fluent Release 16.2 Copyright 2015 ANSYS, Inc.. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: Jul 08 2015 18:34:35 EDT Build Id: 10212 -------------------------------------------------------------- This is an academic version of ANSYS FLUENT. Usage of this product license is limited to the terms and conditions specified in your ANSYS license form, additional terms section. -------------------------------------------------------------- Cleanup script file is /bigwork/nhmgefte/cleanup-fluent-tane-n008-11575.sh > Reading "/bigwork/nhmgefte/fluent/PALOG/komega/komega_rad.cas"... 26250 quadrilateral cells, zone 1, binary. 30 2D wall faces, zone 2, binary. 51595 2D interior faces, zone 3, binary. 6 2D wall faces, zone 4, binary. 150 2D wall faces, zone 5, binary. 1364 2D wall faces, zone 6, binary. 230 2D wall faces, zone 7, binary. 30 2D wall faces, zone 8, binary. 27156 nodes, binary. 27156 node flags, binary. Building... mesh materials, interface, domains, mixture phase-1 phase-2 interaction zones, bottom (phase-1) default_interior-1 (phase-1) default_exterior-1 (phase-1) wall_inlet (phase-1) wall_outlet.1 (phase-1) wall_outlet (phase-1) bottom (phase-2) default_interior-1 (phase-2) default_exterior-1 (phase-2) wall_inlet (phase-2) wall_outlet.1 (phase-2) wall_outlet (phase-2) fluid-1 (phase-1) fluid-1 (phase-2) outlet (phase-1) outlet (phase-2) wall_outlet wall_outlet.1 wall_inlet default_exterior-1 default_interior-1 bottom outlet fluid-1 Done. > Reading "/bigwork/nhmgefte/fluent/PALOG/komega/-13-02000.dat"... Done. > > iter continuity x-velocity y-velocity k omega time/iter 10 0.0000e+00 0.0000e+00 0.0000e+00 5.5997e-06 6.4506e-03 0:38:54 19990 20 0.0000e+00 0.0000e+00 0.0000e+00 6.1432e-06 4.1727e-03 0:38:34 19980 30 0.0000e+00 0.0000e+00 0.0000e+00 7.3137e-06 3.0246e-03 0:38:16 19970 40 0.0000e+00 0.0000e+00 0.0000e+00 7.3917e-06 2.0389e-03 0:38:03 19960 50 0.0000e+00 0.0000e+00 0.0000e+00 6.6184e-06 1.3130e-03 0:37:53 19950 ! 60 solution is converged 60 0.0000e+00 0.0000e+00 0.0000e+00 5.4897e-06 8.1829e-04 0:37:39 19940 > Writing "/bigwork/nhmgefte/fluent/PALOG/komega/freitag.dat"... Done. > Thank you very much for any help!!! |
It looks like it is 100% working and doing whatever it is you told it to do, whatever that is.
If you already have a .dat file then you should not be initializing again which would clear the current solution and replace the fields with your initial conditions. It converged, based on your convergence criteria, after 60 iterations. It didn't abort randomly. Can you try doing the same steps through the GUI to see if you get a different result? Also, if you are learning to run batch mode, you can run locally w/o a cluster but use only TUI commands. You can do this with either gui or nogui but just practice with only using TUI commands and nothing else. |
