relative humidity more than 100%!! unable to understand why this is happening
Old   November 29, 2015, 16:03
Default relative humidity more than 100%!! unable to understand why this is happening
amasugi14 is on a distinguished road
Hi, i am simulating airflow in human nasal cavity in extreme climate. however, the relative humidity exceeds 100%.
It would be so helpful if anyone can check my boundary condition, and give me advice on how to tackle this problem.
my boundary condition is as below;
wall,
temperature 307.15k
water mass fraction 0.0344 (temperature 34c, humidity 100%) based on psychromatic chart.
ambient temperature,
pressure outlet
pressure 0 gauge
temperature 278.15
water mass fraction 0.003752 (temperature 5c, humidity 70%) based on psychromatic chart.
inlet (nasopharynx),
velocity inlet
velocity -1.25
temperature 307.15
actually, based on the previous thread, ive also tried to ignore the boundary condition at the inlet (temperature 0, water mass fraction 0), however, the same problem still occurred (relative humidity exceed 100%).
Last edited by wyldckat; December 6, 2015 at 11:56. Reason: added link to "other thread"
amasugi14 is offline   Reply With Quote
Old   December 1, 2015, 21:01
Default HELP..URGENT.. relative humidity more than 100%!!
i'm simulating airflow within the human nasal cavity in extreme climate. I've used species transport, and defined water mass fraction (using Phsycrometric chart) at the wall and outlet (ambient air). However, when i checked the contour (Relative humidity>compute) the maximum RH value within the nasal cavity exceeds 100%.
I've tried so many ways to encounter this problem, unfortunately still couldn't solve it. It is much appreciated if anyone could help me with this.
Best regards.
relative humidity, species transport
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
relative humidity and temperature by outlet Bing FLUENT 5 March 7, 2014 06:03
Relative humidity subhas.hunasikatti@gmail. Fluent UDF and Scheme Programming 0 January 8, 2014 03:26
Relative humidity amar FLUENT 0 April 14, 2009 20:59
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
