November 30, 2015, 16:06 |
2D Venturimeter Analysis Problems
Sean
Rep Power: 10 |
Hi guys,
I have a problem to model the flow of water through a ventuimeter using ANSYS WORKBENCH 14; FLUENT, however I am a bit of a beginner and am having some problems setting up my solutions. I had set up the analysis as 2D, and modelled the top half of the geometry (the line of symmetry is set up as an axis in the set-up) and created a bias in the mesh towards the venturi throat. In my set up I use the k-epsilon model as the flow is turbulent and have enhanced wall treatment enabled. The fluid is water and is defined as such, and enters the pipe at a velocity of 4.77 m/s as defined in ANSYS. The inlet is set as a velocity inlet, centreline as an axis, wall as a wall and outlet as a pressure outlet. However when I run my calculation the solution does not converge and I am continually faced with being told that the flow is reversed? Any help at all on how to successfully setup my problem and obtain solutions would be kindly received. Cheers |
November 30, 2015, 17:45 |
Rep Power: 10 |
Hi!
Did you elongate the outlet to avoid backflow? |
November 30, 2015, 18:30 |
Sean
Rep Power: 10 |
December 1, 2015, 00:48 |
Rep Power: 10 |
Perfect! Good luck and keep us updated!
December 1, 2015, 15:00 |
Sean
Rep Power: 10 |
December 1, 2015, 15:49 |
Rep Power: 10 |
Yep. The flow probably detaches at the venturi's wall. This creates a backflow that difficults the convergence.
Since this is probably your case, you may want to check the k omega sst model, instead of the k epsilon ewt. In models with detached flow like venturis, it may underpredict the pressure losses. But i'm new also in this, so dont trust me much |
fluent, reversed flow, venturi |
Problems Running Seakeeping Analysis in Headwave | JeffStrath | STAR-CCM+ | 0 | April 28, 2015 14:37 |
Acoutic fan analysis | arunraj | FLUENT | 0 | October 4, 2012 05:54 |
Eigenfrequencies static and modal analysis | Laura_mecheng | ANSYS | 1 | May 15, 2012 03:40 |
How to recover unfinished CFX analysis with backup file | DiddyPablo | CFX | 3 | December 18, 2011 06:14 |
(urgent)parallel analysis problems | Karteek | Siemens | 1 | July 18, 2008 19:04 |
