Getting data for geometry
Old   December 4, 2015, 10:12
Default Getting data for geometry
enass
enass massoud is on a distinguished road
I have a case file and i want to get length of geometry and some dimensions, is that possible?
If so how please?
enass massoud is offline   Reply With Quote
Old   December 4, 2015, 13:54
Dave M.
Dave_88 is on a distinguished road
you have different options:
  • General > Check: gives you the minimum and maximum coordinates of your entire(!) mesh. If your geometry can be derivated from that, this might help.
  • Results > Contours > Contours of...> Mesh >...coordinate. Results in a contour plot where the differenz colors stand for a certain coordinate, depending on the one you chose (e.g. x-coordinate).
  • Import mesh to ICEM CFD (unless you did not use it for your meshing anyways) > use the measuring of length
  • I am not quite sure, but I think CFX has a length scale (as you can see in the Workbench)
unfortunately Fluent does not support an easy way to measure distances and similar. I hope one of the options mentioned above help.
Regards
Dave
Dave_88 is offline   Reply With Quote
Old   December 8, 2015, 11:56
enass
Thank you so much that was really helpful
Old   December 8, 2015, 11:58
enass
let me ask you one more question please, as you said i can import the mesh. So once imported i can modify it? One more thing please, can i import the geometry created in case file to for example ANSYS Design modeller to modify it?
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
