October 23, 2018, 19:16 |
Rotating pipe analysis
Hamed Abdul Majeed
Rep Power: 13 |
Water flow in a pipe from P1 to P2, where P1>P2. The pipe is rotating about the axis shown in figure. How to analyze such a problem!
In addition to the frictional loses, the flow has to overcome the centrifugal force! what is the chemical name of alum |
October 23, 2018, 20:10 |
Rep Power: 9 |
With mesh motion under cell zone conditions
October 27, 2018, 14:22 |
Hamed Abdul Majeed
Rep Power: 13 |
October 28, 2018, 13:21 |
Rep Power: 9 |
No, moving frame are only moves the coodinate system -> sliding wall, no effect of the mass moment of inertia from the fluid.
October 29, 2018, 08:18 |
Lucky
Rep Power: 65 |
Even easier is to just go to boundary conditions and make it a moving wall. No need for the mesh to move.
Moving reference frame does not provide the motion. But you probably should use a moving reference frame anyway for post-processing purposes so that you do not need to decompose the velocity field into the rotating part and relative part. |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Rotating cylinder analysis in Fluent | sercan85 | ANSYS | 0 | August 15, 2016 06:03 |
Pipe Flow Analysis | akshayygarg | FLUENT | 3 | March 4, 2011 08:57 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 17:06 |
Rotating machine analysis | Hans | Main CFD Forum | 1 | November 19, 2002 06:49 |
