How to choose the YPLUS value in two-phase flows?
Like Tree1Likes
  • 1 Post By LuckyTran
Old   February 10, 2007, 19:29
Default How to choose the YPLUS value in two-phase flows?
Niewlande
For two-phase Euler-Euler multiphase model + turbulence model, how to select the reported "yplus" values for meeting the requirement of law-of-the-wall?
I mean, there are two "yplus" values from different phases (say, YPLUS for air & solid). Then, which one should be chosen for the grid adjustment?
Especially, for the MIXTURE and DISPERSED models (k-epsilon multiphase turbulence model), how to make decision for the YPLUS value?
Please give your idea.
Old   December 7, 2015, 10:22
Jakub
undziabundzia is on a distinguished road
Anyone knows ? Shall we move that topic, to "meshing problems". I need very much informations, about Yplus wall for water and air, becouse i working on two-phase flow around ship.
Thank You for sharing Your knowledge. You are great !!
undziabundzia is offline   Reply With Quote
Old   December 7, 2015, 15:08
Lucky
There is no ambiguity in the meaning or definition of y+ for two-phase flows. Just because there may be two different phases in the domain, at a particular location the fluid can only be 1 phase. The exception is the VOF model which allows properties of different phases to be blurred together.
As for post-processing, there really is only one y+ value for the wall adjacent cell (whatever the wall adjacent value is). One y+ will be undefined for the phase that doesn't exist at the wall.
Meshing is no different than single-phase simulation. If you want to predict the grid requirements, then that always requires some knowledge of the expected flow field. Otherwise you can do trial-and-error.
Lennart.H likes this.
Old   December 7, 2015, 15:43
Jakub
Thank You for your reply, Friend.
So If I have Volume of Fluid with Air and Water, that have diffrent y+ from calculator. Which Y+ should I choose ?
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
yplus value in two phase flow P.R.Naren FLUENT 0 September 5, 2006 02:10
Yplus [y+] value for gas solid two phase flow P.R.Naren Main CFD Forum 0 September 5, 2006 02:04
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
References fr 2 phase flows in porous media Madhavan Main CFD Forum 2 June 29, 2000 14:01
