convergence problem of a simple DPM simulation
Hi everybody,
I'm trying to simulate a 2-phase flow passing some bends using Discrete Phase Method. air is the career phase and the discrete phase is coal powder. I have convergence problem and tried several trick to control the solution, but I'm afraid I wasn't able to make it converge adequately. I will be appreciate if everybody share with me his suggestion for my trouble. Here there are some specification: Grid: Quad, 3D iso-thermal condition, incompressible gas sst k-omega turbulent model, injection from surface, steady state solver two-way turbulent coupling: active Thanks in advance |
hi amin,
did you solved your problem? i have a similar problem. steady continuous phase converged without DPM. but when i interact them (two way coupling) it became impossible. in some tutorials that i found in the web there are some advises for this problem: -increase "number of continuos phase iterations per DPM iteration" -in "Numerics" tab "Enable Node based averaging" (this can increase solution time) etc. but i tried all of them and nothing changed!! valuable comments appreciated! |
