periodic rotational conditions in Fluent
Like Tree3Likes
  • 1 Post By CeesH
  • 1 Post By CeesH
  • 1 Post By CeesH
Old   December 18, 2015, 04:07
Default periodic rotational conditions in Fluent
Aja
aja1345 is on a distinguished road
I have one question:
In Fluent, should be generated same mesh in rotational faces for creating periodic rotational conditions?
Is there a way that unmatched meshes are applied for creating periodic rotational conditions?
Thanks
aja1345 is offline   Reply With Quote
Old   December 18, 2015, 05:12
Cees Haringa
CeesH is on a distinguished road
As far as I am aware, you need a 100% match between the left and right hand side faces of your rotational domain. Essentially, FLUENT simply 'deletes' one of the sides, and treats the other one as being inbetween the 2 zones - which means the faces must match up with the cells they cover.
Best,
Cees
aja1345 likes this.
CeesH is offline   Reply With Quote
Old   December 18, 2015, 05:33
Aja
Thanks.
But according to the following text(Ansys Fluent manual):
35.9.1. Create/Edit Mesh Interfaces Dialog Box
Periodic Boundary Condition
allows you to create a non-conformal periodic boundary condition interface.
Non-conformal is unmached mesh?? What does your exact meaning of conformal mesh?
I am grateful that guide me more.
Old   December 18, 2015, 07:09
Cees Haringa
Although I have no experience with that option, it seems to be possible indeed: http://aerojet.engr.ucdavis.edu/flue...ug/node194.htm
aside from this page, I cannot help you further, however.
Best,
Cees
aja1345 likes this.
Old   December 18, 2015, 07:34
Aja
Thank.
What is the exact meaning of non-conformal periodic boundary condition interface?
non-conformal=unmached mesh? right?
Old   December 18, 2015, 07:41
Cees Haringa
yes, for conformal the mesh on both sides needs to match exactly. for non-conformal, the faces do not need to match pefectly. So a tet-hex comination would be non-conformal.
aja1345 likes this.
Translational Periodic Boundary Conditions HeatTransferFan CFX 19 December 12, 2016 11:15
Fluent bug when using periodic conditions? mdg2 FLUENT 1 February 25, 2016 10:25
PEMFC module + multiple periodic boundary conditions vkrastev FLUENT 2 December 22, 2014 04:15
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 17:00
Activate Periodic Conditions IvanCFD FLUENT 3 May 13, 2010 07:02
