Converting 3D Model for 2D Analysis
Old   December 19, 2015, 02:18
Default Converting 3D Model for 2D Analysis
Abayomi T. LAYENI
yomilayeni is on a distinguished road
Send a message via Skype™ to yomilayeni
Hi, I am trying to run a 2D analysis and I have a 3D physical model.
yomilayeni is offline   Reply With Quote
Old   December 19, 2015, 06:36
abc
nanakumawat is on a distinguished road
could you please specify your problem in details...
nanakumawat is offline   Reply With Quote
Old   December 19, 2015, 07:22
Abayomi T. LAYENI
I am trying to convert my 3D simulation to the One in the attached Document and not getting a convergence. I think my Physical 2D modelling may be the cause
Old   December 22, 2015, 05:18
abc
I have gone through your problem .according to me you are trying to simulate the natural convection heat transfer problem right.so plz select proper material density.you can try with boussinesq approach.
Old   December 23, 2015, 03:43
Abayomi T. LAYENI
Thanks for going through the document. I selected air as the material and used the boussinesq approach by selecting the gravity option and the full boussinesq in the k-epsilon turbulence model option. What else do I need to do? That's why I think it may be my 2D physical model that is the problem. The diagram seems so simple but how do I take care of the width in 2D?
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
how to set turbulence model and inflation layers in analysis of an aircraft realpilot FLUENT 2 April 24, 2013 20:26
CFD Analysis of Model Aircraft Sashankh FLUENT 0 December 1, 2008 22:49
DRAG ANALYSIS ON 3D FLIGHT MODEL vidhyasagar s FLUENT 0 February 14, 2008 10:52
