vortex and high velocity order in VOF interface?
Like Tree1Likes
  • 1 Post By LuckyTran
Old   January 10, 2016, 05:11
Default vortex and high velocity order in VOF interface?
Qumars
Qumars is on a distinguished road
Dear colleagues
I am simulating a water flow in an oil media. size of cylinder and throat is .3 mm and .05 mm respectively.
In interface between water and oil, some vortexes occurs and velocity has high values,(inlet is 0.001 m/s but velocity is around 1 m/s in interface)
numerical schemes are, PISO,PRESTO, Quick and Geo-reconstruct
What is the reseaon?
mesh and v-countor has attached below
regards
Qumars is offline   Reply With Quote
Old   January 11, 2016, 16:12
Lucky
It looks qualitatively reasonable.
The question is how much of the 1 m/s is explainable because of the difference in properties.
Do you have the right surface tension and wetting angle (and density obviously)?
Old   January 12, 2016, 05:05
Qumars
dear Lucky Tran,
thanks for your reply,
actually this vortex haven't any effect on flow direction, but they reduce time step, because of courant number. it takes weeks to become steady.
it is interesting that i run the this model in openFoam and the highest velocity was .06 m/s. about ten time less than.
surface tension is .05 and contact angle is 30.
is there any solution?
best regard.
Old   January 12, 2016, 14:28
Lucky
If no blatant errors then compare your discretization schemes (especially for the time-step). My guess there's limiters being activated for OF that isn't happening in Fluent.
lourencosm likes this.
Circular cylinder vortex shedding/strouhal number too high li0012in CFX 7 April 28, 2016 21:56
high mesh resolution causing vortex pimpleFoam mvoss OpenFOAM Running, Solving & CFD 2 March 8, 2012 08:06
Vortex shedding, FSI-analysis, turbulence numerics tallknuseren CFX 3 May 10, 2010 05:31
Vortex method vs High Reynolds number Weili Main CFD Forum 1 August 4, 2006 02:15
Free vortex - forced vortex Armin Hofstädter Main CFD Forum 2 November 17, 1998 19:55
