VOF simulation with Fluent for a droplet impact with a particle
Old   January 16, 2016, 23:08
Thumbs up Droplet impact with a static particle-VOF simulation
Hossein1 is on a distinguished road
Hello all,
Using VOF, I'm simulating a water droplet that falls down on a spherical static particle. I'm using 2D model in axisymmetric mode. Using the mesh shown in Fig. 1, when I give the droplet 2 m/s, the result that Fluent gives me is very similar to my experimental results (droplet detaches from the particle surface like a liquid branch as shown in Fig. 2) Pls. click to enlarge the picture.
However, when I increase the velocity to 5 m/s with the same mesh, Fluent cannot give good results and as you see in Fig. 3, the liquid passes over the particle like a simple barrier without detaching from it (while based on my experimental results, in 5 m/s the liquid should be detached from particle surface more compared to 2 m/s)
I decided to use a finer mesh. However, not only it didn't help for for 5 m/s but also with finer mesh the same problem happened even for V=2 m/s that I already got good results with the previous mesh (see Figs. 4,5)
Could you please help me to know what I should do in such a situation in order to be able to get good results for droplet velocity of 5 m/s?
Thanks for taking time to help me.
PS: time step: 3e-7, particle diameter: 2 mm, droplet diameter: 3.5 mm, particle contact angle: 118 deg
Hossein1 is offline   Reply With Quote
droplet-particle impact, vof
Pilch and CA Erdman droplet break up in fluent air_fun FLUENT 0 June 25, 2014 15:33
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 12:27
2D Vs 3D VOF Fluent calculations sachinthakre FLUENT 0 February 5, 2013 11:35
Convert VOF droplet to DPM particle via UDF TedBrogan Fluent UDF and Scheme Programming 1 May 1, 2012 11:01
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 05:38
