VOF simulation with Fluent for a droplet impact with a particle |
January 16, 2016, 23:08 |
Droplet impact with a static particle-VOF simulation
Rep Power: 10 |
Hello all,
Using VOF, I'm simulating a water droplet that falls down on a spherical static particle. I'm using 2D model in axisymmetric mode. Using the mesh shown in Fig. 1, when I give the droplet 2 m/s, the result that Fluent gives me is very similar to my experimental results (droplet detaches from the particle surface like a liquid branch as shown in Fig. 2) Pls. click to enlarge the picture. Fig1.jpg Fig2.jpg However, when I increase the velocity to 5 m/s with the same mesh, Fluent cannot give good results and as you see in Fig. 3, the liquid passes over the particle like a simple barrier without detaching from it (while based on my experimental results, in 5 m/s the liquid should be detached from particle surface more compared to 2 m/s) Fig3-V=5 crash.png I decided to use a finer mesh. However, not only it didn't help for for 5 m/s but also with finer mesh the same problem happened even for V=2 m/s that I already got good results with the previous mesh (see Figs. 4,5) Fig4-finer mesh.jpg Fig5- V=2 finer mesh.png Could you please help me to know what I should do in such a situation in order to be able to get good results for droplet velocity of 5 m/s? Thanks for taking time to help me. PS: time step: 3e-7, particle diameter: 2 mm, droplet diameter: 3.5 mm, particle contact angle: 118 deg Last edited by Hossein1; January 17, 2016 at 00:39. |
droplet-particle impact, vof |
Pilch and CA Erdman droplet break up in fluent | air_fun | FLUENT | 0 | June 25, 2014 15:33 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 12:27 |
2D Vs 3D VOF Fluent calculations | sachinthakre | FLUENT | 0 | February 5, 2013 11:35 |
Convert VOF droplet to DPM particle via UDF | TedBrogan | Fluent UDF and Scheme Programming | 1 | May 1, 2012 11:01 |
Fluent Remote Simulation Facility Service (RSF) di | Rami | FLUENT | 2 | June 4, 2008 05:38 |
