Drag on an Airfoil
Old   January 31, 2016, 17:17
Default Drag on an Airfoil
a m s
Easyqus is on a distinguished road
Hi
I have been having an issue with Fluent outputting the drag on an airfoil.
I am aware that Fluent is able to calculate and output the drag on the airfoil's surface but when I go to 'report' a single value appears on the screen. I am using an unsteady but periodic flow and would like to know the pressure force on the airfoil at each tilmestep. I tried to do this instead by monitoring the static pressure on the airfoil surface (monitors->integral->static pressure) which, as it is an integral, is outputted as Pa*m^2 which is the units of Newtons i.e. a force. However I can not be certain in what direction this force is acting i.e. it is not a drag force acting in the x-direction.
Any ideas on how to measure the drag force on a surface at each timestep? All help is greatly appreciated, thank you!
Easyqus is offline   Reply With Quote
airfoil 2d, drag force, monitor
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
Airfoil with simpleFoam and kOmegaSST: high drag values? Tsiolkovsky OpenFOAM Running, Solving & CFD 6 November 21, 2018 05:56
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
