February 21, 2019, 12:18 |
Mesh independent study
Santhosh
Rep Power: 7 |
I am trying to model a flow over an airfoil. While doing mesh independence study, the value of Cl does not seem to converge to a particular value when I reduce the mesh size. I get fluctuating results during the process. What might be wrong in the process?
February 22, 2019, 09:54 |
Lucky
Rep Power: 65 |
Probably you don't maintain consistent mesh topology / mesh quality as you change you cell size. This is why it's important to always do these mesh dependence studies. Sometimes (always), a lot more things are changing than you think. It's also why it's better to call them mesh dependence or mesh sensitivity studies. Because the idea that the solution is actually independent of the mesh is quite absurd.
February 23, 2019, 00:14 |
Santhosh
Rep Power: 7 |
What you are saying is true. Every time I reduce the mesh size the orthogonal quality and aspect ratio differs slightly. How do I maintain those two parameters while changing mesh size? Thanks for your reply.
February 23, 2019, 01:28 |
Rep Power: 8 |
I don't know what program you use to generate your mesh but "Orthogonal Quality" and "Aspect Ratio" are available in Ansys Meshing. You can check this parameters before transfer your mesh to Fluent. You need to keep the scale of your mesh costant as possible as in your mesh independent study. If you change the bias or scale of your mesh along y axis, then you need to change the bias or scale scale of your mesh along x axis. and keep in mind that before doing mesh dependent study, you need to create a mesh as good as possible using these parameters. You need to learn the definition of both parameters before using them. Thus please read this page to know how to create a decent mesh before doing mesh dependent study:
https://www.sharcnet.ca/Software/Ans...h_quality.html |
February 23, 2019, 02:15 |
Santhosh
Rep Power: 7 |
I am using ANSYS meshing (v19.0). But I dont seee an option to specify orthogonal quality or Aspect ratio. Just an option to view them in quality option. I am doing 2D flow over an airfoil and I just reduce the mesh size by decreasing the overall size of the mesh by face sizing.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Mesh independent study | ThePhoton | Main CFD Forum | 1 | November 15, 2015 15:13 |
[ICEM] (New to CFD) How to do a mesh refinement study w/ Fluent? | JAviles | ANSYS Meshing & Geometry | 1 | June 25, 2014 12:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
