Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh |
February 9, 2016, 11:39 |
Emanuele Burberi
I'm trying to run a simulation of two meshing gears using 2.5D remeshing method of Dynamic meshing in FLUENT. I have defined the deforming dynamic zone on the symmetry plane where gears are meshing and it works, as shown in the attached figure. The problem is the following: I need a high refinement level of grid into the approach region of the teeth where they reach the minimum distance (without contact because I have slightly increased the wheelbase dimension)*in order to appropriately detect the flow field info the meshing region. Since it seems that the user can define the grid refinement parameters , on the deforming dynamic zone, only exploiting constant values (for Minimum and Maximum Lenght Scale and Maximum Skeweness) the same*stringent refinement level is applied on all the symmetry and consequently on all the extruded dynamic domain which makes the computational costs of my calculation*too much expensive. Does someone know if it is possible to define, by means of UDF for example, a local variation of*such*grid refinement parameters in order to makes grid refinement stringent into the meshing region and coarser in the otherpart of the dynamic domain? Is it possible to define a local mesh refinement in a DEFORMING dynamic mesh zone using dynamic mesh method in FLUENT? |
2.5d remeshing, dynamic mesh, grid refinement parameter, local mesh refinement, maximum lenght scale |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
