[Sponsors] | |||||
could not correct the face handedness for ... |
Onur Özcan
Rep Power: 13 ![]() |
Hi all,
I have run acrossed a problem that is relevant to ''could not correct the face handedness for ... '' . I am working on 3d steady state. Actually The problem has reveealed after some walls has been ''coupled'' .Some direction are available to solve it like TUI commands ( like repair).But it doesn't still be fixed. Can anyone help me out with this? Kind Regards, |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
It's a meshing problem and not a Fluent problem. You probably have a really bad quality mesh or the mesh was not saved in a proper format.
#3 | |
Onur Özcan
Thank you for prompt reply. The reasons why you have defined are not enough. Let me put it this way, before ''coupled walls'' has not been defined ,that is, two surface treats like two walls.That's why some convection heat transfers are not enough.So, I need to idenfity two surface like the one.After coupled walls has been defined, the problem above I have referred to reveals, Kind Regards, |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | September 18, 2024 06:52 |
| [blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
| face handedness | neelamkumar1988 | Main CFD Forum | 2 | November 22, 2012 13:25 |
| [Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
| Face handedness | vivek | FLUENT | 0 | June 9, 2005 06:25 |
